By Dulag Utok
#42309
martinayotte wrote:Yes ! as long as the input voltage is between 0V-1V.
there is this Serial.read command where we can use the arduino tx to send data to the esp8266 rx. are you familiar with its syntax? I'm a bit having trouble with my project. It's actually a school project. :)
By martinayotte
#42312 What do you mean ?
Serial class provide Serial.available() to figure out if RX buffer has something to read, if it is the case, simply do Serial.read() to read the character one by one and place it into you own buffer for processing.
If the source of the RX is an Arduino board, beware that you need voltage divider to drop the 5V to 3V of the ESP.
By Dulag Utok
#42313
martinayotte wrote:What do you mean ?
I send data from an uno board with this program. so every 5 seconds, the arduino board transmits sensor reading.
int sensorPin =0;
int sensorValue = 0;
int sensorValue2 = 0;
void setup(){
pinMode(sensorPin,INPUT);
// read the value from the sensor:
sensorValue = analogRead(sensorPin);
sensorValue2=map(sensorValue,0,720,0,100);
if(sensorValue2>100)
sensorValue2=100;
Serial.println(sensorValue2);
delay(5000);
To receive the signal, i tried using this code on an esp8266-1. this is just a basic webserver page to display the sensor reading but the values it displays does not coincide with the values sent by the uno board.
const char* ssid = "pistinani";
const char* password = "redled01";
int value;
WiFiServer server(80);
delay(10);
// Connect to WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.println("");
// Start the server
server.begin();
// Print the IP address
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.println("/");
if (!client) {
return;
if(Serial.available()>0){
value = Serial.read();
// Return the response
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connetion: close");
client.println("Refresh: 5");
client.println(""); // do not forget this one
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.print("Soil moisture: ");
client.print(value);
client.println("<br><br>");
client.println("Automatic drip irrigation<br><br>");
client.println("</html>");
delay(1);
client.stop();
Serial.println("Client disonnected");
Serial.println("");
By martinayotte
#42316 Serial.read() is returning characters one by one of the string, not the actual integer value from sensor that you sent.
You need to acumulate all the characters until newline and then you can send it to Wifi client.
Code: Select all  char buf[64];
  int i = 0;
  if (Serial.available()) {
    int inByte = Serial.read();
    buf[i] = (char)inByte;
    if (inByte == '\r' or inByte == '\n' or i > (sizeof(buf) - 1)) {
      buf[i] = 0;
      i = 0;
      client.println(buf); // here we sent the whole line to the WiFi client
