At the moment, I have a ESP8266 connected to an Arduino Uno through a 3.3V regulator, GPIO0 and GPIO2 are unused. I can send ANY AT command through the serial monitor of the Arduino Uno perfectly fine, and obtain a normal reply. However, when I attempt to upload any code at all, I get
esptool v0.4.5 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to ck
setting baudrate from 115200 to 115200
setting port from COM1 to COM3
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
stat C:\Users\Michael\AppData\Local\Temp\build7227402767538495982.tmp/wifi_setup.cpp.bin success
setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
flush start
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
read 0, requested 1
trying to connect
flush start
flush complete
espcomm_send_command: receiving 2013 bytes of data
read 0, requested 1
error: failed reading byte
warning: espcomm_send_command: cant receive slip payload data
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
warning: espcomm_sync failed
error: espcomm_open failed
I've tried just about everything I could find on this topic - connecting GPIO0 to ground, connecting GPIO0 and GPIO02 both to Vcc, switching Rx with Tx etc. to no avail.
Any ideas?
