11:57:03 **** Build of configuration Default for project esphttpd ****
mingw32-make.exe -f C:/Espressif/examples/esphttpd/Makefile all
CC user/base64.c
user/base64.c: In function 'base64_decode':
user/base64.c:54:3: error: array subscript has type 'char' [-Werror=char-subscripts]
if(isspace(in[ii])) continue;
cc1.exe: all warnings being treated as errors
mingw32-make.exe: *** [build/user/base64.o] Error 1
C:/Espressif/examples/esphttpd/Makefile:170: recipe for target 'build/user/base64.o' failed
and how can i make webpages.espfs in eclipse
folny82 wrote:Hi
How to make a set webpages.espfs able to Eclipse ?
prozac wrote:FYI, using the esp-open-sdk, the code as is seems to throw a warning about using a char as an array index in the base64.c file (if(isspace(in[ii])). By declaring another char and assigning in[ii] to that char and using that in the subsequent lines, the warning goes away. Not sure if s the compiler or what, but thought you should know in case someone else gets tripped up.
Lets get the party started and +1
[url=https://www.banggood.com/custlink/KvGGhGF4wG[/url]
I like ESP8266 and ESP8285 and ESP32
