ESP8266WebServer server(200);
IPAddress ip(192, 168, 1, 100); //Node static IP
IPAddress gateway(192, 168, 1, 1);
server.on("/parseIFTTT", parseIFTTT);
void parseIFTTT() {
String message;
message += server.args();
message += "\n";
for (uint8_t i = 0; i < server.args(); i++) {
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
Serial.println(message);
server.send(200, "text/plain", "Success " + message);
is done to route the parseIFTTT request to this parseIFTTT() method.
I have done port forwarding and using the duckdns to access this server from outside. This is my duckdns address
http://xxxxxx.duckdns.org:200/parseIFTTT
When I make a POST using a POSTMAN tool with content type as text/plain , the body contents are shown in the serial monitor as
plain
--body contents--
But when the same request is made from IFTTT the serial monitor shows nothing but plain as empty .Initially I felt the issue is with IFTTT. But that is not the issue as when I use the WiFiWebServer example in the arduino , using the following code
String req = client.readString();
Serial.println(req);
client.flush();
I see the data from IFTTT as :
POST /parseIFTTT HTTP/1.1
Content-type: text/plain
host: xxxxxx.duckdns.org:200
content-length: 27
x-newrelic-id: XAMGV15QGwQJVllRDgQ=
x-newrelic-transaction: PxQFA1NbAQQJVwJWA1dSB0YdUFIOFQZOEgEPVA5ZBFYGXAwECFgFAFcUG0MHUwoLBAcDAxVs
Connection: close
{"value":"test data from IFTTT"}
So I believe I am doing something wrong with the server.args(). I am under the impression that server.args() should give the body contents used in the POST whether contentType is text/plain or x-www-form-urlencoded.
Am I doing something wrong or with the server.args() can't we get the body data from the POST request ?
