Thanks to your inputs, I finally got it working the way I wanted
First, the show :
http://screencast.com/t/vCmgwHL54
Then, the code:
* File manager part of this code taken from the FSBrowser sample, part of the ESP8266WebServer library for Arduino environment. Copyright (c) 2015 Hristo Gochkov. All rights reserved.
* This code also contains excerpts of the examples included in the libraries used, as well as inputs on the esp8266.com forums.
* Special thanks go to @martinayotte & @igrr for thir insightful help
#include <ESP8266WebServer.h>
#include <ESP8266HTTPClient.h>
#include <FS.h>
#define SERIAL_DEBUG Serial
#define MAX_CACHE_ITEMS 10
#define CACHE_TTL 1*60*1000 // 1 minute
String cachedUrl[MAX_CACHE_ITEMS]; // Urls cached in SPIFFS
long cacheTime[MAX_CACHE_ITEMS]; // To store time the actual page was last fetched
String cacheContentType[MAX_CACHE_ITEMS]; // To store the Content-Type of files in cache
const char* ssid = "********";
const char* password = "********";
ESP8266WebServer server(80);
//holds the current upload
File fsUploadFile;
uint8_t buffer[5840];
//format bytes
String formatBytes(size_t bytes){
if (bytes < 1024){
return String(bytes)+"B";
} else if(bytes < (1024 * 1024)){
return String(bytes/1024.0)+"KB";
} else if(bytes < (1024 * 1024 * 1024)){
return String(bytes/1024.0/1024.0)+"MB";
} else {
return String(bytes/1024.0/1024.0/1024.0)+"GB";
// From https://github.com/zenmanenergy/ESP8266-Arduino-Examples/blob/master/helloWorld_urlencoded/urlencode.ino
unsigned char h2int(char c) {
if (c >= '0' && c <='9'){
return((unsigned char)c - '0');
if (c >= 'a' && c <='f'){
return((unsigned char)c - 'a' + 10);
if (c >= 'A' && c <='F'){
return((unsigned char)c - 'A' + 10);
return(0);
String urlDecode(String str) {
String encodedString="";
char c;
char code0;
char code1;
for (int i = 0; i < str.length(); i++) {
c=str.charAt(i);
if (c == '+'){
encodedString+=' ';
else if (c == '%') {
i++;
code0=str.charAt(i);
i++;
code1=str.charAt(i);
c = (h2int(code0) << 4) | h2int(code1);
encodedString+=c;
else {
encodedString+=c;
return encodedString;
// From http://hardwarefun.com/tutorials/url-encoding-in-arduino
String URLEncode(const char* msg) {
const char *hex = "0123456789abcdef";
String encodedMsg = "";
while (*msg!='\0'){
if( ('a' <= *msg && *msg <= 'z')
|| ('A' <= *msg && *msg <= 'Z')
|| ('0' <= *msg && *msg <= '9') ) {
encodedMsg += *msg;
} else {
encodedMsg += '%';
encodedMsg += hex[*msg >> 4];
encodedMsg += hex[*msg & 15];
msg++;
return encodedMsg;
String getContentType(String filename){
if(server.hasArg("download")) return "application/octet-stream";
else if(filename.endsWith(".htm")) return "text/html";
else if(filename.endsWith(".html")) return "text/html";
else if(filename.endsWith(".css")) return "text/css";
else if(filename.endsWith(".js")) return "application/javascript";
else if(filename.endsWith(".png")) return "image/png";
else if(filename.endsWith(".gif")) return "image/gif";
else if(filename.endsWith(".jpg")) return "image/jpeg";
else if(filename.endsWith(".ico")) return "image/x-icon";
else if(filename.endsWith(".xml")) return "text/xml";
else if(filename.endsWith(".pdf")) return "application/x-pdf";
else if(filename.endsWith(".zip")) return "application/x-zip";
else if(filename.endsWith(".gz")) return "application/x-gzip";
return "text/plain";
void handleFileUpload(){
if(server.uri() != "/edit") return;
HTTPUpload& upload = server.upload();
if(upload.status == UPLOAD_FILE_START){
String filename = upload.filename;
if(!filename.startsWith("/")) filename = "/"+filename;
SERIAL_DEBUG.print("handleFileUpload Name: "); SERIAL_DEBUG.println(filename);
fsUploadFile = SPIFFS.open(filename, "w");
filename = String();
} else if(upload.status == UPLOAD_FILE_WRITE){
//SERIAL_DEBUG.print("handleFileUpload Data: "); SERIAL_DEBUG.println(upload.currentSize);
if(fsUploadFile)
fsUploadFile.write(upload.buf, upload.currentSize);
} else if(upload.status == UPLOAD_FILE_END){
if(fsUploadFile)
fsUploadFile.close();
SERIAL_DEBUG.print("handleFileUpload Size: "); SERIAL_DEBUG.println(upload.totalSize);
void handleFileDelete(){
if(server.args() == 0) return server.send(500, "text/plain", "BAD ARGS");
String path = server.arg(0);
SERIAL_DEBUG.println("handleFileDelete: " + path);
if(path == "/")
return server.send(500, "text/plain", "BAD PATH");
if(!SPIFFS.exists(path))
return server.send(404, "text/plain", "FileNotFound");
SPIFFS.remove(path);
server.send(200, "text/plain", "");
path = String();
void handleFileCreate(){
SERIAL_DEBUG.println("handleFileCreate: " + path);
if(path == "/")
if(SPIFFS.exists(path))
return server.send(500, "text/plain", "FILE EXISTS");
File file = SPIFFS.open(path, "w");
if(file)
file.close();
else
return server.send(500, "text/plain", "CREATE FAILED");
path = String();
void handleFileList() {
if(!server.hasArg("dir")) {server.send(500, "text/plain", "BAD ARGS"); return;}
String path = server.arg("dir");
SERIAL_DEBUG.println("handleFileList: " + path);
Dir dir = SPIFFS.openDir(path);
path = String();
String output = "[";
while(dir.next()){
File entry = dir.openFile("r");
if (output != "[") output += ',';
bool isDir = false;
output += "{\"type\":\"";
output += (isDir)?"dir":"file";
output += "\",\"name\":\"";
output += String(entry.name()).substring(1);
output += "\"}";
entry.close();
output += "]";
server.send(200, "text/json", output);
bool handleFileRead(String path){
SERIAL_DEBUG.println("handleFileRead: " + path);
if(path.endsWith("/")) path += "index.htm";
String contentType = getContentType(path);
String pathWithGz = path + ".gz";
if(SPIFFS.exists(pathWithGz) || SPIFFS.exists(path)){
if(SPIFFS.exists(pathWithGz))
path += ".gz";
File file = SPIFFS.open(path, "r");
size_t sent = server.streamFile(file, contentType);
file.close();
return true;
return false;
bool handleProxy() {
SERIAL_DEBUG.println("handleProxy");
if (!server.hasArg("url")) {
SERIAL_DEBUG.println("url parameter is missing");
server.send(200, "text/plain", "Please use http://<this_device>/proxy?url=<encoded_url_without_http>");
else {
String realUrl = urlDecode(server.arg("url"));
if (realUrl.indexOf("://") == -1) {
// No protocol. Add http://
realUrl = "http://" + realUrl;
if (realUrl.indexOf("/", 7 /* after the http:// */) == -1 && realUrl.indexOf("?") == -1) {
// Only a domain name. Add trailing slash
// TODO: should handle the case where realUrl contains arguments: http://www.google.com?q=test
realUrl = realUrl + "/";
SERIAL_DEBUG.println(String("Real url is ") + realUrl);
/* Try to find it in cache */
int cacheIndex = -1;
long oldestCacheTime = -1;
int oldestCacheIndex = -1;
for (int i = 0; i < MAX_CACHE_ITEMS; i++) {
if (cachedUrl[i] == realUrl) {
SERIAL_DEBUG.println(String("Cache match ! This URL is entry #") + i);
cacheIndex = i;
if (oldestCacheTime == -1 || cacheTime[i] < oldestCacheTime) {
oldestCacheTime = cacheTime[i];
oldestCacheIndex = i;
long itemCacheTime;
if (cacheIndex == -1) /* not found in cache */ {
SERIAL_DEBUG.println(String("Discarding oldest entry #") + cacheIndex + ": " + cachedUrl[cacheIndex]);
cacheIndex = oldestCacheIndex; /* recycle the oldest one */
itemCacheTime = -1;
else {
itemCacheTime = cacheTime[cacheIndex];
// Test if we can return the cached copy
long now = millis();
if ( itemCacheTime == -1 /* no cache */
|| itemCacheTime > now /* millis() wrapped around */
|| now - itemCacheTime > CACHE_TTL /* cache is outdated */) {
SERIAL_DEBUG.println("Fetching from server into cache");
// Configure client to retrieve Content-Type header
HTTPClient http;
const char * headerkeys[] = {"Content-Type", "Location"} ;
size_t headerkeyssize = sizeof(headerkeys)/sizeof(char*);
//ask to track these headers
http.collectHeaders(headerkeys, headerkeyssize );
// Init client
SERIAL_DEBUG.println("[HTTP] begin...");
http.begin(realUrl);
// Connect to the real server
SERIAL_DEBUG.println("[HTTP] GET...");
int httpCode = http.GET();
if (httpCode < 0) {
SERIAL_DEBUG.print("[HTTP] GET failed, error: ");
SERIAL_DEBUG.println(http.errorToString(httpCode));
return false;
SERIAL_DEBUG.printf("[HTTP] Status code=%d\n", httpCode);
if (httpCode != HTTP_CODE_OK) {
SERIAL_DEBUG.println("[HTTP] Location is " + http.header("Location"));
return false;
// Prepare cache file
File cache = SPIFFS.open(String("/cache/") + cacheIndex, "w");
if (!cache) {
SERIAL_DEBUG.println("Could not create cache file");
int len = http.getSize();
SERIAL_DEBUG.println("Response type:" + http.header("Content-Type") + " - Size=" + len);
WiFiClient* stream = http.getStreamPtr();
// read all data from server
while (http.connected() && (len > 0 || len == -1)) {
// get available data size
size_t size = stream->available();
if (size) {
// read up to buffer size
int c = stream->readBytes(buffer, ((size > sizeof(buffer)) ? sizeof(buffer) : size));
// write it to Serial
// SERIAL_DEBUG.write(buffer, c);
// write it to cache
cache.write(buffer, c);
if (len > 0) {
len -= c;
delay(1);
cache.close();
cachedUrl[cacheIndex] = realUrl;
cacheTime[cacheIndex] = now;
if (http.hasHeader("Content-Type")) {
cacheContentType[cacheIndex] = http.header("Content-Type");
else {
// Fallback, probably missing index.html when omitted...
cacheContentType[cacheIndex] = getContentType(realUrl);
SERIAL_DEBUG.println(realUrl + " (type=" + cacheContentType[cacheIndex] + ") stored in cache entry #" + cacheIndex + " at " + now + "ms");
// And return cached file to the browser
SERIAL_DEBUG.println("Returning contents from cache");
// Open cache file for reading
File cache = SPIFFS.open(String("/cache/") + cacheIndex, "r");
if (!cache) {
SERIAL_DEBUG.println("Could not open cache file");
// And stream it back
size_t sent = server.streamFile(cache, cacheContentType[cacheIndex]);
cache.close();
SERIAL_DEBUG.println("Response sent");
SERIAL_DEBUG.begin(115200);
delay(10);
SERIAL_DEBUG.println();
SERIAL_DEBUG.print("Initializing Wi-Fi");
// Connect to WiFi network
WiFi.begin(ssid, password);
SERIAL_DEBUG.print(".");
SERIAL_DEBUG.println(" Done.");
// Initialize SPIFFS and clear cache
SERIAL_DEBUG.println("Initializing SPIFFS cache...");
if (!SPIFFS.begin()) {
SERIAL_DEBUG.println("SPIFFS init failed");
Dir dir = SPIFFS.openDir("/cache");
while (dir.next()) {
SERIAL_DEBUG.println("Deleting " + dir.fileName());
SPIFFS.remove(dir.fileName());
cacheTime[i] = 0;
cachedUrl[i] = "";
// Initialize and start local web server
//list directory
server.on("/list", HTTP_GET, handleFileList);
//list directory
server.on("/proxy", HTTP_GET, handleProxy);
//load editor
server.on("/edit", HTTP_GET, [](){
if(!handleFileRead("/edit.htm")) server.send(404, "text/plain", "FileNotFound");
//create file
server.on("/edit", HTTP_PUT, handleFileCreate);
//delete file
server.on("/edit", HTTP_DELETE, handleFileDelete);
//first callback is called after the request has ended with all parsed arguments
//second callback handles file uploads at that location
server.on("/edit", HTTP_POST, [](){ server.send(200, "text/plain", ""); }, handleFileUpload);
//called when the url is not defined here
//use it to load content from SPIFFS
server.onNotFound([](){
if(!handleFileRead(server.uri()))
//get heap status, analog input value and all GPIO statuses in one json call
server.on("/all", HTTP_GET, [](){
String json = "{";
json += "\"heap\":"+String(ESP.getFreeHeap());
json += ", \"analog\":"+String(analogRead(A0));
json += ", \"gpio\":"+String((uint32_t)(((GPI | GPO) & 0xFFFF) | ((GP16I & 0x01) << 16)));
json += "}";
server.send(200, "text/json", json);
json = String();
server.begin();
SERIAL_DEBUG.println("HTTP server started");
SERIAL_DEBUG.print("Ready. Please direct your browser to: http://");
SERIAL_DEBUG.println(WiFi.localIP());
server.handleClient();
And finally a few words:
As I had difficulties determining if the issues were in the filling or returning phases of the caching, I thought it would be good to explore what actually was in the cache, and thought easier to add my code to the FSBrowser sample that comes with the ESP8266WebServer library. I just added an "/proxy" handler to perform proxying.
This also means that the cache is now of a higher level: the first versions buffered everything coming from the server (headers included), while this new version only stores the actual page.
Another new feature is that the server is now able to proxy about any GET request, as the realUrl is now passed as a parameter to the ESP. This also means I now have to remember what URL is currently being cached, as well as its mime-type. And, while I was at it, I added the possibility to cache multiple urls (the number of urls can be specified as a #define, as well as the time-to-live of the files in the cache).
For this example, the TTL is 1 minute and you can see in the video that the eetimes cache is still up-to-date and returned immediately upon second call, while the nytimes is out-of-date when I perform the second call and gets refreshed from the server.
The good:
- It works . I admit I couldn't pinpoint the exact reason of the problems I encountered in the previous versions, but they now seem to be solved anyway
- Support additional parameters to the external server as part of the "url" parameter (URLencoded):
http://192.168.0.18/proxy?url=www.googl ... 3Fq%3Dtest (note that it also works without being URLencoded, although it is probably not a legal URL - http://192.168.0.18/proxy?url=www.google.com/?q=test)
The bad:
- It is really slow in the end. Fetching the 280k homepage of eetimes.com takes 35 seconds, plus 15 seconds to return it to the client, so in the end it is a bit slower than a 56k modem... (is that normal ? - my ESP is next to my access point...)
- If the page links to resources (images, js, css) in an absolute way but without a FQDN, those won't work. Fully qualified links work (bypassing the proxy) and relative links should work too - adding more load to the single-thread server. Although the demo uses html web pages, this code clearly was not designed to proxy websites, but more APIs or other simple resources.
- The code handles missing "http://" prefix and missing trailing slash after the hostname (seems many servers are picky and send a redirect if it is missing) in the URL passed in parameter, but don't expect too much and use full URL if possible (particularly if parameters are included too)
- Performing redirect in case of status 3xx is not implemented but would be fairly easy as the actual location is already decoded and dumped on the console. However, more and more sites request to switch to https (facebook, twitter), and it would require more work in this case.
All in all, I'm pretty satisfied I can go on with my project, and I hope it can help others facing a similar situation.
Kind regards,
Vicne
Keywords: esp8266 http simultaneous proxy circumvent XSS cross site scripting json api caching redirect
