great software.
One could point you are trying to change in yourself, send the ESP to the client comes first one
character and then delayed the rest. This confuses some clients.
You can not leave this deficiency?
Allex
Explore... Chat... Share...
dacb wrote:This is a nice idea. I'd have to learn more about the protocol. For the ESP boards with more GPIOs available (i.e. not the -01) the flow control lines could be implemented fully. Even with the ESP-01, the free GPIO could be used as RTS or CTS to initiate an Arduino reset.
dacb wrote:uhrheber wrote:pabbllo wrote:How to initialize bridge between 2 arduinos? With 2 ESPs off course.
Disclaimer, I've not tried this, but it seems like one would have to initiate the connection. This firmware, as it stands, only accepts incoming TCP connections. Making outgoing TCP connections is not supported, at this time.
