If I use AT+CIPMUX=1 to enable multi connections, then AT+CIPSERVER=1,80 to enable server and finally back AT+CIPMUX=0 to disable multi connections,
then ESP waits to send data till I finish with sending to one. This is really good feature!
Explore... Chat... Share...
