- Sun Aug 14, 2016 11:02 am
#52935
I second this.
Tried to compile latest NodeMCU both from the online builder and locally.
I flashed exactly as told in the docs:
Code: Select allesptool --port /dev/ttyUSB0 write_flash -fm dio -fs 32m 0x00000 ./bin/0x00000.bin 0x10000 ./bin/0x10000.bin
But the end result is the same: garbage on tty, constantly blinking LED.
The firmware fits entirely into ROM: 0x00000.bin - 28416 byte, 0x10000.bin - 448615 byte, 2,1Mb total as ELF-binary.
Modules I tried to build: ADC, Bit, CJSON, CoAP, Crypto, DHT, Encoder, Enduser, File, GPIO, HTTP, I2C, mDNS, MQTT, Net, Node, 1-Wire, PCM, Perf, PWM, Sigma_Delta, SNTP, SPI, Timer, UART, Wi-Fi.
Board: NodeMCU v1 (Manufacturer E0, Product 4016).
So, what's the deal? How do I fix it? And if I can't, what's the latest working build for this board?
