picstart wrote:I tested the above code and it will stop working after several dozen cycles.
It goes to sleep but won't wake up.
This is an obvious omitted requirement that needs adding for the compilationCode: Select allextern "C"
#include "user_interface.h"
Hi picstart,
Indeed you are right,
That part of code should be included , I took the functions from a larger set of code hence i forgot to put it there in the post thanks for the reminder !
Orcanbull
Yes i can help you , Yes you can send me a PM with a question - No i won't make the code for you
