rudy wrote:I am currently running your code. Just got it up and running with my LCD additions and name node name translation.
curious what code you have for name node name translation ... can you share?
Explore... Chat... Share...
sfranzyshen wrote:rudy wrote:I am currently running your code. Just got it up and running with my LCD additions and name node name translation.
void txtFrom(uint32_t var) {
switch (var) {
case 888274678:
whoIs="104";
break;
case 2131077732:
whoIs="102";
break;
case 886613302:
whoIs="103";
break;
case 888453468:
whoIs="107";
break;
case 2131077688:
whoIs="106";
break;
case 883356933:
whoIs="110";
break;
default:
whoIs=var;
break;
myNodeID=(mesh.getNodeId());
txtFrom(myNodeID);
lcd.setCursor(0, 0);
lcd.print("I am ");
lcd.print(whoIs);
Serial.println(""); // print real node ID
Serial.print("my NodeID is ");
Serial.print(mesh.getNodeId());
Serial.print(" ");
Serial.println(mesh.getNodeId(),HEX);
lcd.setCursor(0, 1);
lcd.print("Got from ");
txtFrom(from); // find out who from is. fills whoIs string
lcd.print(whoIs);
