- Sun Oct 23, 2016 11:00 am
#56985
addicted wrote:read the doc.
know what you are doing. why you are doing.
then you can solve problems.
frustrated of solving problem?? stop living
"Read the Doc" without a reference is as useless as the rest of our comment.
1. Espressif documents programmable pull up/down GPIO pins but then never states what state at boot all pins are, that I can find.
2. Espressif never documents the values used in pull up/down that I can find
3. The reference to work done on NodeMCU Flash tool would indicate the Github site would reflect this, the last update to
https://github.com/nodemcu/nodemcu-flasher was Sept. 30 2015.
4. The readthedocs.io (
https://nodemcu.readthedocs.io/en/master/en/flash/) is dated and the links are broken.
So "addicted", please point out something that I can read that is relevant otherwise keep your snide, demeaning comments to yourself.
