By marcelstoer
#57591
Unc3nZureD wrote:According to the guide:
NodeMCU will automatically flash this file to the right place on first boot, if the sector appears to be empty.
So, I didn't burn esp_init_data_default.bin, as I'm trying to burn the latest master (non-dev) firmware.
Note how the master and dev documentation is different in this respect atm (because the fix for this is not on master yet).
By marcelstoer
#57593
Unc3nZureD wrote:The error message is exactly the same again. Flashing succeed, but I can't connect to the device :/
It's really odd that esptool.py can communicate over COM6 but other tools can't - at least not after you flashed the firmware.
By Unc3nZureD
#57622
marcelstoer wrote:Note how the master and dev documentation is different in this respect atm (because the fix for this is not on master yet).
Please have a look at the 2nd part of my comment. I did try to flash it with the esp_init_data_default, but with that one, it didn't respond either.
(By the way thanks for notifying me about 2 different documentation)
Any other ideas? :/
By Unc3nZureD
#57743 I still can't make it work, could anyone give me an idea how to find the problem? As I'm newbie I don't know many things about ESP* or NodeMCU things.
I would be really glad if someone could tell me any idea :)
Thanks for each idea :)
