By Nisc
#62409 How to power up esp8266 12e? It is fully programmed, I just want to give it power. How to connect?
Here's the picture
By rudy
#62421 Most of the schematics on the net are incomplete. (including the ones in the previous poster's link) Most do not show the required pull-up resistor on D2. The following schematic is almost adequate. Eliminate the deep-sleep resistor if you are not using that function.
Add a capacitor across the Vcc and ground. Use a 0.1uF as shown but also a larger cap like a 100uF-470uF. Make these as close to the power pins on the module.
Make sure that any voltages applied to the ESP8266 are no greater than 3.3 volts.
