I've used digitalWrite to send a GPIO high and low to turn a simple led on/off but i'm not sure I'm can use the same method for higher voltages, in this case 5V solar panel.
Should i be using a relay and if so are 3.3v relay around. This is abattery powered project so i want to conserved battery life.
Thanks in advance.
