Would it be possible to add a way to set the sntp server in the time function? I have a 24/7 server here that i use to sync all my other computer and i would like to be able to connect to it.
Thank you
Explore... Chat... Share...
Moderator: Mmiscool
else if ( fname == F("timesetup") && num_args > 0 ) {
String bla;
SaveDataToFile("TimeZone", String(args[0]));
SaveDataToFile("DaylightSavings", String(args[1]));
SaveDataToFile("TimeServer", String(args[2]));
configTime(LoadDataFromFile("TimeZone").toFloat() * 3600, LoadDataFromFile("DaylightSavings").toInt(), LoadDataFromFile("TimeServer"), "pool.ntp.org");
*value_str = "";
return PARSER_STRING;
