I have code which control thermometer, OLED and nanoservo via MQTT. I want to refresh temperature every 10s. It works but my servo receive command only when temperature is refreshed. How can I configure my loop so my servo can receive MQTT command anytime I send it?
Here in my code (I combined several example codes...):
#include <Servo.h>
#include <PubSubClient.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Wire.h>
#include "SH1106.h"
#include "thermometer.h"
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 14 // je D5 was 2 (D4)
// Setup a oneWire instance to communicate with any OneWire devices
// (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
SH1106 display(0x3c, D1, D2);
#define DEMO_DURATION 3000
typedef void (*Demo)(void);
int demoMode = 0;
int counter = 1;
// Update these with values suitable for your network.
const char* ssid = "******";
const char* password = "******";
const char* mqtt_server = "192.168.100.220"; /// MQTT Broker
const char* topic_state = "/blinds/state";
const char* topic_command = "/blinds/command";
IPAddress my_ip (192, 168, 100, 224);
IPAddress my_gateway (192,168, 100, 1);
IPAddress my_subnet (255, 255, 255, 0);
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
Servo myservo;
int state = 0;
int prevstate = 0;
int dirc = 0;
int spintime = 0;
int servoPin = D4; //CHANGE TO WHATEVETR PIN YOUR USING
void reconnect();
void callback(char* topic, byte* payload, unsigned int length);
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
// Start up the library
sensors.begin();
// Initialising the UI will init the display too.
display.init();
display.flipScreenVertically();
display.setFont(ArialMT_Plain_10);
void servo_move() {
Serial.println("State Change. Rotating Servo");
if ( dirc == 180) {
client.publish(topic_state,"open");
else if (dirc == 0) {
client.publish(topic_state,"close");
myservo.attach(servoPin);
myservo.write(dirc);
delay(spintime);
myservo.detach();
Serial.println("Returning to main loop");
return;
void setup_wifi() {
delay(10);
Serial.println(ssid);
WiFi.setPhyMode(WIFI_PHY_MODE_11N);
WiFi.config(my_ip, my_gateway, my_subnet);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("");
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
char *blindcommand = (char *) payload; // convert mqtt byte array into char array
blindcommand[length] ='\0'; // Must delimit with 0
Serial.print(blindcommand);
if (strcmp(blindcommand,"open") == 0) {
Serial.println(" 433MHZ OPEN COMMAND RECEIVED");
dirc = 180; // direction for servo to run
spintime = 50; // << CHANGE TO WHATEVER TIME YOU NEED TO OPEN YOUR BLINDS
state = 1; //sets current state
else if (strcmp(blindcommand,"close") == 0) {
Serial.println(" 433MHZ CLOSE COMMAND RECEIVED");
dirc = 0;
spintime = 150; // << CHANGE TO WHATEVER TIME YOU NEED TO CLOSE YOUR BLINDS
state = 2; //sets current state
if (state != prevstate) {
Serial.println("State change!");
servo_move();
prevstate = state;
char temperatureVonku[15];
String tempUnit = " °C";
void temperature(){
float temperatureFloat;
sensors.requestTemperatures();
temperatureFloat = sensors.getTempCByIndex(0);
dtostrf(temperatureFloat, 7, 1, temperatureVonku);
client.publish("temp/outside", temperatureVonku); /// send char
delay(10000);
void dispTempVonku() {
display.drawRect(1, 1, DISPLAY_WIDTH -1, DISPLAY_HEIGHT -1);
// Font Demo1
// create more fonts at http://oleddisplay.squix.ch/
display.setTextAlignment(TEXT_ALIGN_LEFT);
display.setFont(Roboto_Bold_12);
display.drawString(5, 5, "Temp: ");
display.drawXbm(7, 24, Img_width, Img_height, thermometer);
display.setTextAlignment(TEXT_ALIGN_CENTER);
display.setFont(Roboto_Bold_28);
display.drawString(64, 22, temperatureVonku + tempUnit);
void dispTempVnutri() {
display.setFont(ArialMT_Plain_16);
display.drawString(64, 22, "Hello World");
Demo demos[] = {dispTempVonku, dispTempVnutri};
int demoLength = (sizeof(demos) / sizeof(Demo));
long timeSinceLastModeSwitch = 0;
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("ESP8266Client", "******", "******")) {
Serial.println("connected");
client.subscribe(topic_command);
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
temperature();
if (!client.connected()) {
reconnect();
client.loop();
// clear the display
display.clear();
// draw the current demo method
demos[demoMode]();
display.setTextAlignment(TEXT_ALIGN_RIGHT);
display.drawString(10, 128, String(millis()));
// write the buffer to the display
display.display();
if (millis() - timeSinceLastModeSwitch > DEMO_DURATION) {
demoMode = (demoMode + 1) % demoLength;
timeSinceLastModeSwitch = millis();
counter++;
//delay(10000);
Thank you.
