On is A0 01 01 A2
Off is A0 01 00 A1
Explore... Chat... Share...
jummi wrote:I just got a new badge.
Disconnect the esp8266-01.
I give 5 volt voltage to the plate.
The D2 led D2 flashes constantly.
According to the schematic is the output to the relay.
I should not flash.
The supply voltage is correct.
Any ideas?
