By avaccaro
#74548 I am experiencing a strange behavior using interrupts on a NodeMCU.
I simply connected an LED + resistor on digital port D5 and I was trying to make it blink when I receive an interrupt on another pin.
Here the code:
const int ch0 = D5;
const byte interruptPin1 = D1;
const int triggertime = 1000;
int triggers = 0;
void sendPulse(int chan){
  digitalWrite ( chan, HIGH );
  delay (triggertime);
  digitalWrite ( chan, LOW );
  triggers ++;
  Serial.print("Got trigger ");
  Serial.println(triggers);
void handleInterrupt() {
  Serial.println("Got interrupt 1");
  sendPulse(ch0);
  pinMode ( ch0, OUTPUT );
  digitalWrite ( ch0, LOW );
  Serial.begin ( 115200 );
  pinMode(interruptPin1, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(interruptPin1), handleInterrupt, FALLING);
I attached a button to digital pin D1 and I would like to see the LED turn on for 1 second when the button is pressed.
I don't actually care of how many interrupts get triggered: I only want that when the button is pressed the LED gets powered for 1 second.
Everything works fine for a few clicks, then the LED does not turn on any longer when I press the key, while on the serial monitor I still see that the code is fully executed (interrupts detected and handlers processed).
What am I doing wrong?
By tele_player
#74617 It’s still not a good idea to delay in an interrupt handler. Safer to set a variable in the handler, and have loop() check the variable to see if button was pressed.
By reaper7
#74619 as @tele_player wrote, inside interrupt handle set only flag
Code: Select allvolatile bool myintflag = false;
  if ( myintflag == false ) // optional: only when the previous call has been fully handled in loop
    myintflag = true;       // mandatory: set flag
  if ( myintflag == true ) {
    sendPulse(ch0);
    myintflag = false;     // mandatory: reset flag
