By quackmore
#89612 if everything is fine on the server side you may want to check the client side
you could check your client against this echo server
https://www.websocket.org/echo.html
or you could verify if a different client works
for instance one like "websocket-test-client"
https://chrome.google.com/webstore/detail/websocket-test-client/fgponpodhbmadfljofbimhhlengambbn
By john123
#89613 Ok, I am looking at it...
On this website: https://www.websocket.org/echo.html
I got the messages: "CONNECTED" and the "This browser supports WebSocket".
I run the example code from this website:
https://www.tutorialspoint.com/websockets/websockets_opening_connections.htm#:~:text=Once%20a%20connection%20has%20been,handshake%20between%20client%20and%20server.&text=All%20you%20have%20to%20do,the%20URL%20of%20your%20server.
with the IP that the ESP8266 writes on the serial (from the server code that I have posted to my first message), and the message I get on the serial is:
Code: Select allGot Message:
or
followed by two ASCII symbols...
and this happens everytime I refresh the browser...
Also I installed the extension you have posted, Iopen it and I put the IP address of the ESP8266, I press "Open" and it stucks in "CONNECTING" mode...
Any idea??
Thanks
#update: The google extension works!!! I had another client running that's why it was stuck! You are amazing! Thanx..
2 Questions:
1) In case I want the ESP8266 be accessible from more than 1 clients, can it work?
2)In case I want to access from an android phone, what should I do?
Thanks a lot for your help
By quackmore
#89615 I'm glad you figured it out
I really did nothing...
Code: Select all1) In case I want the ESP8266 be accessible from more than 1 clients, can it work?
it should, you may want to check with the server docs
Code: Select all2)In case I want to access from an android phone, what should I do?
now that you have tested your server
build your own client application, it's just an html doc with some js,
then you can open it in whichever browser including android chrome for example
you will find a working example on the echo site, just below the echo section
Code: Select allhttps://www.websocket.org/echo.html
