pyserial or esptool directories not found next to this upload.py tool.
An error occurred while uploading the sketch
A setup problem perhaps? …but I am not solving it and could use a little help, please. More detailed info follows that may help. Thanks in advance.
Mac Hardware Overview:
Model Name: MacBook Pro
Model Identifier: MacBookPro12,1
Processor Name: Dual-Core Intel Core i7
Processor Speed: 3.1 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache (per Core): 256 KB
L3 Cache: 4 MB
Hyper-Threading Technology: Enabled
Memory: 16 GB
System Firmware Version: 424.0.0.0.0
SMC Version (system): 2.28f7
Serial Number (system): C2QQ501KGM13
Hardware UUID: 20FFAD40-1AC3-586B-B71F-103FFEC4EADF
Provisioning UDID: 20FFAD40-1AC3-586B-B71F-103FFEC4EADF
System Software Overview:
System Version: macOS 11.0.1 (20B50)
Kernel Version: Darwin 20.1.0
Boot Volume: Macintosh HD
Boot Mode: Normal
Computer Name: Gregory’s MacBook Pro
User Name: Gregory Baker (gregorybaker)
Secure Virtual Memory: Enabled
System Integrity Protection: Enabled
Time since boot: 2:13
Arduino:
Version: 1.8.13
Obtained from: Identified Developer
Last Modified: 6/16/20, 5:43 AM
Kind: Intel
Signed by: Developer ID Application: ARDUINO SA (7KT7ZWMCJT), Developer ID Certification Authority, Apple Root CA
Example Sketch: 0.1 Basics/Blink
Preference Linked: http://arduino.esp8266.com/stable/packa ... index.json
Hardware Manager Loaded: ESP8266 Community version 2.7.4
Compile and Upload Binary:
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/gregorybaker/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/gregorybaker/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/gregorybaker/Documents/Arduino/libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=legacy,ssl=all,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=0000_0000 -ide-version=10813 -build-path /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821 -warnings=none -build-cache /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_cache_722106 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-4-b40a506 -prefs=runtime.tools.mkspiffs-2.5.0-4-b40a506.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-4-b40a506 -prefs=runtime.tools.mklittlefs.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/mklittlefs/2.5.0-4-fe5bb56 -prefs=runtime.tools.mklittlefs-2.5.0-4-fe5bb56.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/mklittlefs/2.5.0-4-fe5bb56 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-4-b40a506.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506 -prefs=runtime.tools.python3.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/gregorybaker/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/gregorybaker/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/gregorybaker/Documents/Arduino/libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=legacy,ssl=all,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=0000_0000 -ide-version=10813 -build-path /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821 -warnings=none -build-cache /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_cache_722106 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-4-b40a506 -prefs=runtime.tools.mkspiffs-2.5.0-4-b40a506.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-4-b40a506 -prefs=runtime.tools.mklittlefs.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/mklittlefs/2.5.0-4-fe5bb56 -prefs=runtime.tools.mklittlefs-2.5.0-4-fe5bb56.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/mklittlefs/2.5.0-4-fe5bb56 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-4-b40a506.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506 -prefs=runtime.tools.python3.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
Using board 'nodemcuv2' from platform in folder: /Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4
Using core 'esp8266' from platform in folder: /Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4
Detecting libraries used...
/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/include -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/lwip2/include -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/cores/esp8266 -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/variants/nodemcu /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/sketch/Blink.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/include -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/lwip2/include -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/cores/esp8266 -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/variants/nodemcu /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/sketch/Blink.ino.cpp -o /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/preproc/ctags_target_for_gcc_minus_e.cpp -DARDUINO_LIB_DISCOVERY_PHASE
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 /Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/signing.py --mode header --publickey /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/public.key --out /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/core/Updater_Signing.h
/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/include -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/lwip2/include -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/cores/esp8266 -I/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/variants/nodemcu /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/sketch/Blink.ino.cpp -o /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_cache_722106/core/core_94ad119316d92b784f277a81a16e495d.a
Linking everything together...
/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-gcc -CC -E -P -DVTABLES_IN_FLASH /Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/ld/eagle.app.v6.common.ld.h -o /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/local.eagle.app.v6.common.ld
/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-gcc -fno-exceptions -Wl,-Map -Wl,/var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/Blink.ino.map -g -w -Os -nostdlib -Wl,--no-check-sections -u app_entry -u _printf_float -u _scanf_float -Wl,-static -L/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/lib -L/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/lib/NONOSDK22x_190703 -L/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/ld -L/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/libc/xtensa-lx106-elf/lib -Teagle.flash.4m2m.ld -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -o /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/Blink.ino.elf -Wl,--start-group /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/sketch/Blink.ino.cpp.o /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_cache_722106/core/core_94ad119316d92b784f277a81a16e495d.a -lhal -lphy -lpp -lnet80211 -llwip2-536-feat -lwpa -lcrypto -lmain -lwps -lbearssl -laxtls -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc -Wl,--end-group -L/var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821
/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 /Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/elf2bin.py --eboot /Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/bootloaders/eboot/eboot.elf --app /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/Blink.ino.elf --flash_mode dio --flash_freq 40 --flash_size 4M --path /Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin --out /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/Blink.ino.bin
Creating BIN file "/var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/Blink.ino.bin" using "/Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/bootloaders/eboot/eboot.elf" and "/var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/Blink.ino.elf"
/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 /Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/signing.py --mode sign --privatekey /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/private.key --bin /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/Blink.ino.bin --out /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/Blink.ino.bin.signed --legacy /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/Blink.ino.bin.legacy_sig
/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 /Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sizes.py --elf /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/Blink.ino.elf --path /Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin
Executable segment sizes:
IROM : 228624 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26752 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1248 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 688 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 24880 ) - zeroed variables (global, static) in RAM/HEAP
/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-size -A /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/Blink.ino.elf
Sketch uses 257312 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 26816 bytes (32%) of dynamic memory, leaving 55104 bytes for local variables. Maximum is 81920 bytes.
/Users/gregorybaker/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 /Users/gregorybaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/upload.py --chip esp8266 --port /dev/cu.usbserial-0001 --baud 115200 --before default_reset --after hard_reset write_flash 0x0 /var/folders/h7/wf7nxlvj6jj3r1hw4ghnj0yw0000gn/T/arduino_build_28821/Blink.ino.bin
Error:
____________________
Again, thanks, greg.
