i think you should...
Maybe thats a good place to gather information about all connections outside the chip.
- 1. How to proper connect CH_PD pin
2. RESET pin (floating?)
3. GPIO0, GPIO2
Explore... Chat... Share...
Setting high level on pin configured sa output means high level and can drive LED.setting outpin to low can also driver led.
On the boot GPIO's are configured as inputs.you drive led after boot.
To drive LED's GPIO's are configured as outputs.
So, if You prepare schematic straight for drive LED's You can have problems to proper reboot chip.i dont know about that.
If You play with GPIO good option with capacitors is to set GPIO2 as input an pullup before (expecting) reset chip
try making it sink driver
