By eriksl
#90077 Never pull any GPIO to either low or high without using a resistor. During the boot process almost all GPIO are temporarily an output for various signals. If you pull them hard down or up, you can damage the output circuitry.
By John Karij
#90858 I built a pcb adapter for flashing ESP-12 using CH340G to connect with USB. It connects with ESP-12 using pogo pins.
You could get a bare pcb from here if you want to test it. You need to cut the pcb using a cutting disc to separate the two boards.
