Moderator: eriksl
eriksl wrote:I would already be very happy with the CPU running at 400 Mhz and even more if we can keep the APB at 80 Mhz.
I have the code now in front of me. The very first thing that strikes me is that the code is laced with calls to gcc floating point calculation/conversion functions. Very weird. Also some of the code in the routine is garbage, I assume it's data storage, not code.
Maybe the floating point is becouse some dividers result on float numbers, for example 1040/15 would be 69.33... MHz
eriksl wrote:I'd expect that such calculations would be done in fixed point arithmetic (i.e. multiply all number by a constant so you don't get a fraction).
Yhea, exactly but is the only way to explain the floating point
