When I connect the pump to the relay module and power it, the ESP8266 keep resetting after a few seconds and the relay keep switching on or off by itself even the water level is low. The LCD display just goes crazy by displaying weird character.
I make sure everything is connected to the common ground and I am powering the entire system with a MB102 module which I suspect it could not deliver enough power to the system and causes resetting of the ESP8266?
Thank you!
