By Cleiton Alves
#93330 Hi guys.
I need to read an encoder using the interrupt function by the wemos d1 mini board. However, plotting the readings results in an irregular waveform.
So I tested doing the reading without the interrupt function, just with digitalRead, and when plotting, the waveform was as expected.
In my project I can't just use digitalRead because I can lose readings while executing other functions. Any solution to this problem?
I attached the waveforms that I obtained in each of the tests, through the Serial Plotter. Also, I attached the circuit.
https://drive.google.com/file/d/1WTYii8 ... sp=sharing.
Frequency of the waveform is 40hz.
Below is a simplified code that I used to do just these reading tests:
Code: Select all#define motor 4
#define rotary_encoder 14
boolean signal_encoder = 0;
ICACHE_RAM_ATTR void waveForm() {
  signal_encoder = !signal_encoder;
  pinMode(rotary_encoder, INPUT_PULLUP);
  pinMode(motor, OUTPUT);
 // attachInterrupt(digitalPinToInterrupt(rotary_encoder), waveForm, CHANGE);
  digitalWrite(motor, 1);
  if(digitalRead(rotary_encoder))signal_encoder=1;
  else signal_encoder = 0;
  Serial.println(signal_encoder);
  delay(1);
By pratheek
#93332 Your signal_encoder variable should be declaread as volatile as you are you using it in an interrupt.
Checkout -
https://www.arduino.cc/reference/en/lan ... /volatile/
If you modify a variable inside an interrupt, then you should declare this variable as volatile.
Also in the digitalPinToInterrupt function, the mode is CHANGE. Check if this is what is you want.
