ESP8266 Support WIKI
User Tools
Site Tools
Command disabled: backlink
setup-osx-compiler-esp8266
Table of Contents
Mac OSX Compiler Setups
esp-open-sdk
esp-open-sdk can be installed almost as described in Linux Compiler Setups.
Some problems have been reported if you build the toolchain in a case-insensitive filesystem. To avoid these issues create a case-sensitive volume:
hdiutil create ~/Desktop/eos.dmg -volname "esp-open-sdk" -size 10g -fs "Case-sensitive HFS+"
hdiutil mount ~/Desktop/eos.dmg
cd /Volumes/esp-open-sdk
esp-open-sdk with Brew
Dependencies
brew install gnu-sed --with-default-names
brew tap homebrew/dupes
brew install gperf
brew install grep
brew install autoconf
brew install binutils
brew install gawk
brew install wget
brew install automake
brew install libtool
brew install help2man
binutils is needed for gobjcopy
gawk is required for overwriting the non-gnu awk in my case
If you get the error “configure: error: could not find GNU awk”, run
brew link --overwrite gawk
If you get the error “./zconf.hash.c:167:1: error: conflicting types for 'kconfidlookup'”
brew uninstall gperf
see: https://github.com/pfalcon/esp-open-sdk/issues/236 for reference
esp-open-sdk with MacPorts
Dependencies
sudo port install gsed gawk binutils gperf grep gettext py-serial wget
Get the compiler
git clone https://github.com/pfalcon/esp-open-sdk.git --recursive
Note the –recursive option. This will force git to initialize modules.
Patches
These needs to be applied before build.
sed -i.bak '1s/^/gettext=\'$'\n/' crosstool-NG/kconfig/Makefile
sed -i.bak -e 's/[[:<:]]sed[[:>:]]/gsed/' Makefile
sed -i.bak -e 's/[[:<:]]awk[[:>:]]/\$(AWK)/' lx106-hal/src/Makefile.am
sed -i.bak 's/AM_PROG_AS/AM_PROG_AS\'$'\nAM_PROG_AR/' lx106-hal/configure.ac
setup-osx-compiler-esp8266.txt · Last modified: 2017/03/13 22:41 by polarstate
Page Tools
