tytower wrote:http://www.esp8266.com/viewtopic.php?f=6&t=2872&p=18357#p18357
In there there is a postData function to Sparkfuns server
Thanks tytower, but that appears to be a GET request, not a POST.
Jim
Explore... Chat... Share...
torntrousers wrote:Does the updateThingSpeak function in this sample sketch show you what you want?
void post()
WiFiClient client;
String PostData = "temp=1";
client.println("POST /index.php HTTP/1.1");
client.println("Host: ***EDIT*** your-end-domain.com***EDIT***");
client.println("User-Agent: Arduino/1.0");
client.println("Connection: close");
client.println("Content-Type: application/x-www-form-urlencoded;");
client.print("Content-Length: ");
client.println(PostData.length());
client.println();
client.println(PostData);
delay(10);
while(client.available()){
Serial.print(line);
