Server
#include <ESP8266_TCP.h>
// ESP8266 Class
ESP8266_TCP wifi;
// Target Access Point
#define ssid "AirCard-3D52"
#define pass "52836427"
// Connect this pin to CH_PD pin on ESP8266
#define PIN_RESET 8
void setup()
delay(3000);
// We use Serial1 to interface with ESP8266
// and use Serial to debugging
Serial.begin(9600);
Serial1.begin(115200);
wifi.begin(&Serial1, &Serial, PIN_RESET);
// Check that ESP8266 is available
if(wifi.test())
// Connect to target Access Point
String ip = connectAP();
// Open TCP Server on port 2000 and 30 seconds for connection timeout (Max 2880)
wifi.openTCPServer(2000, 30);
else
// ESP8266 isn't available
Serial.println("Check module connection and restart to try again...");
while(true);
void loop()
// Check for any data has coming to ESP8266
int dataState = wifi.isNewDataComing(WIFI_SERVER);
if(dataState != WIFI_NEW_NONE) {
if(dataState == WIFI_NEW_CONNECTED) {
// Connected with TCP Client Side
Serial.println("Status : Connected");
} else if(dataState == WIFI_NEW_DISCONNECTED) {
// Disconnected from TCP Client Side
Serial.println("Status : Disconnected");
} else if(dataState == WIFI_NEW_MESSAGE) {
// Got a message from TCP Client Side
digitalWrite(13,HIGH);
Serial.println("ID : " + String(wifi.getId()));
Serial.println("Message : " + wifi.getMessage());
wifi.closeTCPConnection(0);
} else if(dataState == WIFI_NEW_SEND_OK) {
// Message transfer has successful
Serial.println("SENT!!!!");
// Access Point Connection Function that you can loop connect to Access Point until successful
String connectAP()
String ip = "0.0.0.0";
while(ip.equals("0.0.0.0"))
ip = wifi.connectAccessPoint(ssid, pass);
if(!ip.equals("0.0.0.0"))
break;
return ip;
Client Side
// ESP8266 Class
ESP8266_TCP wifi;
// TCP Server IP and port
#define serverIP "192.168.1.3"
#define serverPort 2000
#define PIN_RESET 6
// Pin that connected to button to send any message
#define PIN_SEND 22
void setup()
delay(3000);
// Set pin for send command to input mode
pinMode(PIN_SEND, INPUT);
Serial.begin(9600);
if(wifi.test())
delay(1000);
else
while(true);
void loop()
int dataState = wifi.isNewDataComing(WIFI_CLIENT);
Serial.println("Inside If");
Serial.println(dataState);
// Connected with TCP Server Side
// Send a message to TCP Server Side
Serial.println("Sending");
wifi.send("12345678");
// Disconnected from TCP Server Side
Serial.println("Disconnected");
// Message transfer has successfully
} else if(dataState == WIFI_NEW_ALREADY_CONNECT) {
// Already connected with TCP Server Side
Serial.println("Already Connect!!");
// When button for connect to TCP Server Side was pressed
//if(digitalRead(PIN_SEND)>500) {
// Send message to TCP Server Side and waiting for 1 sec
Serial.println("Connect!!");
wifi.connectTCP(serverIP, serverPort);
delay(1000);
delay(50);
String connectAP()
break;
return ip;
