When using the Arduino Capacitive Sensing Library I just need to increase the resistor value to sense my fingers at a greater distance, how could I do that with this program? It has something to do with the timers?
I need to do a capacitive sensor with esp8266 and working under a glass, how did you make the touch? Did you use some glass or just the wire?
Thank you!
Gabi Mihai wrote:Hi,
I've designed a capacitive touch on ESP-01 and I hope that you enjoy it!
Here is the LUA code:
Hi guys , I intend to make the 3-6 channel touch socket with ESP module but I don't know any suitable touch IC for such project , I assume it must read sensor states by I2C link and then command other pins to change status of relay
any clue really appreciated
