After realizing my error I realized the config method was where I needed that setup code. Additionally I found that you had abstracted the code a bit to a variable called ax, which I edited the ticks field of.
Here is the graph as the plant is watered.
ax.push({
id: 'C' + idx,
type: 'linear',
position: 'right',
scaleLabel: {
display: true,
labelString: lst[i].trim(),
fontColor: c
ticks: {
fontColor: c,
beginAtZero: true,
steps: 100,
stepValue: 1,
max: 100
var v = lst[i + 1].trim();
if (v.startsWith('MIN:')) {
this.#_F.push(1);
v = v.substring(4);
} else if (v.startsWith('MAX:')) {
this.#_F.push(2);
v = v.substring(4);
} else this.#_F.push(0);
this.#_cv.push(v);
} this.#_ch.data.datasets = ds;
this.#_ch.options.scales.yAxes = ax;
My next Goal is to have a status div that says whether I need to water it or not.
Inq720 wrote:Jacob Major wrote:I was able to get this part to work mostly I believe. I will note there are a lot of places I need to replace InqHisto with the name of my new histo class but I think I figured it out. I got it running with minimal errors at least.Code: Select allyAxes: [{
display: true,
ticks: {
beginAtZero: true,
steps: 100,
stepValue: 1,
max: 100
That's saying something. I am by no means an expert using chart.js... or even a JavaScript. I remember it being a challenge to get everything the way I wanted... especially the moving of the chart to the left, yet keep a zero at the right edge. I toiled with the idea of even mentioning it for end-user's charting/graphing needs. It implies I need to support it.
I'm glad you got it going... let us see the fruit of your labors when you get a chance.
VBR,
Inq
