By Aledav
#62880 Hello @ Reaper07,
congratulations for the library, the RS232-RS485 converter that uses allows you to overlook the DE / RE lines.
This wiring diagram that I would use for the tests with the ESP01, correct?
I just have to change in SDM.h
#define SDMSER_RX_PIN 2 // RX-D6 (Wemos) -12 - GPIO2 (ESP01)
#define SDMSER_TX_PIN 0 // TX-D7 (Wemos) -13 - GPIO0 (ESP01)
Thanks for the great job
By reaper7
#62881 looks good :)
If You do not use a hardware serial in Your code, then You can also switch to hardware serial on TX/RX pins instead software serial on gpio0/2. It is more stable.
Simply uncomment:
#define USE_HARDWARESERIAL
On software serial I had 1-2 errors per day and the same count of strange esp resets :?
Now I switch to hardware serial and from 15 days any reading errors or esp resets :)
By manmoncang
#65377 Dear @ovdleun
I am from Malaysia doing same thing with you and stuck with nodemcu read info from SDM120.
May i have you code? Then i can learn and understand about SDM to nodemcu. Tqv,
By manmoncang
#65378 Yes... whats wrong with RS485? May Sir @Reaper07 help how to use library with RS485? tqvm and appreciate it if Sir Reaper7 can show the connection and code.
mohsh86 wrote:
ovdleun wrote:@Reaper07,
hehe sorry my bad. ;) Ok, so I hooked up everything last weekend and it works like a charm with the right converter! :D Then I discovered that my code was doing the queries too fast, so I had to put in a 500ms delay and with that, it was succesfully gathering the required information. So thank you very much for the SDM220 lib. ;)
I'll update this reply with a link to my blog post as soon as I've finished it. But for this matter, I just had the wrong RS485 converter. ;o)
KR.
Onno.
Hello,
would you mind telling me what was the wrong RS485 converter and what is the correct one ? i am using this one and am not sure where my problem is, i am using a 5v<->3.3v logic converter, assuming the MAX485 is 5v logic..
