The RFX user guide tells me that its a FTDI FT232R USB interface, and if i read the datasheet correctly, this is a 3.3V serial output.
Do you agree?
Edit: Just read your edit. To avoid modification of the RFX,this could help?
Explore... Chat... Share...
PerH wrote:as a simple signal converter..
