By eriksl
#21082
pvvx wrote:
eriksl wrote:I'm impressed, the sound quality is actually very acceptable!
At what frequency does the pwm run then?
Not classic PWM -> http://www.beis.de/Elektronik/DeltaSigm ... Sigma.html
Output: 2xInegrator: https://github.com/pvvx/mp3_decode/blob ... main.c#L75
Log sample: Rate 48000 x 32 bits.
Thx. I guess you you mean you compensate the lack of duty cycle resolution with more oversampling?
By eriksl
#21083
tytower wrote:
pvvx wrote:
eriksl wrote:I'd expect rather poor sound quality though, as the pwm duty has only 8 bits resolution?
PWM_HACK = PWM 5 bits :)
Its reported elsewhere that it is 10 bit resolution?
Yes, from SDK 1.1.1 PWM seems to be "upgraded" to 10 bits resolution.
That's a lot better, but my simple atmega328p still beats it at large with 16 bits PWM!
By alonewolfx2
#21084 @sprite_tm or @pvvx i am getting this and i am hearing just noise not music, any help?i defined pwm_hack
Code: Select allConnecting to server 188.40.123.50...
Reading into SPI RAM FIFO...
MAD: Decoder start.
dec err 0x0101 (lost synchronization)
Rate 22050
Buffer fill 21908, DMA underrun ct 0, buff underrun ct 0
Buffer fill 21893, DMA underrun ct 0, buff underrun ct 0
By hdrut
#21115
alonewolfx2 wrote:@sprite_tm or @pvvx i am getting this and i am hearing just noise not music, any help?i defined pwm_hack
MAD: Decoder start.
Rate 22050
I had a similar problem. What output pin are you using? GPIO3 (RXD) is the correct one.
Rgds
Horacio
