What do you use to monitor the WiFi traffic?
Explore... Chat... Share...
Squonk wrote:I suggest you buy a prop guard
Squonk wrote:What do you use to monitor the WiFi traffic?
Squonk wrote:speaking about cheaper part: is it possible to replace the AVR with a cheaper MCU?
The ATTINY441 is listed @ $1.65 on DK. I am thinking of an EFM8BB10 @$0.42.
cnlohr wrote:Squonk wrote:What do you use to monitor the WiFi traffic?
cnping https://github.com/cnlohr/cnping ... you also might like https://github.com/cnlohr/wifirxpower
cnlohr wrote:Squonk wrote:speaking about cheaper part: is it possible to replace the AVR with a cheaper MCU?
I've never seen that chip. Though I dislike th 8051 ISA (it's what I first learned and coded in assembly when I was growing up), I would be more than happy to bury the hatchet... On that chip from a technical aspect, it looks as though the only concerns I would have is:
Not 5V tolerant, so it would have to be behind one of my voltage regulators, which means it wouldn't be able to control them.
cnlohr wrote:Would require external voltage divider to monitor the vBat vs the ATTiny which just monitors Vcc against the internal reference.
cnlohr wrote:After some googling I was unable to come up with any I2C Slave examples for that part.
cnlohr wrote:It doesn't look like it has very protected I/O pins.
cnlohr wrote:Soooooo If you wanted to tackle problem 3, and turn it into a splendid I2C Controlled PWM device, I would certainly consider nixing the ATTiny for this thing.
