By JohnnyBlaze
#30349 Hey, this is really great thanks for creating this feature!
I have the ESP-01 and i want to compile the code from pvvx (https://github.com/pvvx/mp3_decode) but i am on MAC OS. Is there a way to compile it on MAC OS / Linux?
Or is there a compiled version, where i can change the SSID & PW + stream-url (after flashing the binary) through a local webserver?
Best regards!
By mrendu43
#31500
pvvx wrote:
alonewolfx2 wrote:Sprite_tm any progress for 512kb flash?
Support all ESP2866 modules (512 Kbytes flash)
Free Flash (512 Kbytes): 200 Kbytes. Free Heap: 20 Kbytes.
MP3-decodec-out uses IRAM Buffer > 20 Kbytes (IRAM: 48k + 16k cache Flash):
Code: Select allFlash Header:
Number of segments: 3
SPI Flash Interface: QIO
SPI CLK: 80MHz
Flash size: 512K
Entry point: 40100004
Segment 1: offset: 40100000, size: 27240
Segment 2: offset: 3ffe8000, size: 1704
Segment 3: offset: 3ffe86b0, size: 6588
Found free IRAM: base:40106a68, size:21912 bytes
Hardware initialized. Waiting for network.
mode : sta(18:fe:34:9f:c0:bf)
add if0
scandone
add 0
aid 2
cnt
connected with mns.ru-6446, channel 1
dhcp client start...
ip:192.168.1.50,mask:255.255.255.0,gw:192.168.1.1
Connecting to server 145.58.52.149...
Reading into SPI RAM FIFO...
MAD: Decoder start.
dec err 0x0101 (lost synchronization)
dec err 0x0235 (bad main_data_begin pointer)
Rate 48000
Buffer fill 14096, DMA underrun ct 0, buff underrun ct 0
Buffer fill 21865, DMA underrun ct 0, buff underrun ct 0
Buffer fill 21889, DMA underrun ct 0, buff underrun ct 0
Buffer fill 21881, DMA underrun ct 0, buff underrun ct 0
Buffer fill 21857, DMA underrun ct 0, buff underrun ct 0
hello
how do i compile your source,
in witch enviorment do you compile this : eclipse, linux or?
