now i want create a simple remote controller ,
so when i push a button (gpio 2)
on the AP, i want to turn on a led(gpio 2) on the client .
now they are connected but i don't' know how to program this....
anybody can help me ??
tnx
Max
Explore... Chat... Share...
-- init.lua
print("Running")
file.close("init.lua")
dofile("wifi_station.lua")
dofile("application.lua")
-- credentials.lua
SSID="your-ssid"
PASSWORD="your-password"
-- wifi_station.lua
-- load credentials, 'SSID' and 'PASSWORD' declared and initialize in there
dofile("credentials.lua")
connected_to_AP = false
-- Define WiFi station event callbacks
wifi_connect_event = function(T)
print("Connection to AP("..T.SSID..") established!")
print("Waiting for IP address...")
if disconnect_ct ~= nil then
disconnect_ct = nil
wifi_got_ip_event = function(T)
print("Wifi connection is ready! IP address is: "..T.IP)
connected_to_AP = true
-- turn on the connection led ...
-- YOUR CODE HERE
wifi_disconnect_event = function(T)
if T.reason == wifi.eventmon.reason.ASSOC_LEAVE then
--the station has disassociated from a previously connected AP
return
print("\nWiFi connection to AP("..T.SSID..") has failed!")
-- turn off the connection led ...
-- YOUR CODE HERE
--There are many possible disconnect reasons, the following iterates through
--the list and returns the string corresponding to the disconnect reason.
for key,val in pairs(wifi.eventmon.reason) do
if val == T.reason then
print("Disconnect reason: "..val.."("..key..")")
break
if disconnect_ct == nil then
disconnect_ct = 1
disconnect_ct = disconnect_ct + 1
print("Retrying connection...(attempt "..(disconnect_ct+1)..")")
-- Register WiFi Station event callbacks
wifi.eventmon.register(wifi.eventmon.STA_CONNECTED, wifi_connect_event)
wifi.eventmon.register(wifi.eventmon.STA_GOT_IP, wifi_got_ip_event)
wifi.eventmon.register(wifi.eventmon.STA_DISCONNECTED, wifi_disconnect_event)
print("Connecting to WiFi access point...")
wifi.setmode(wifi.STATION)
wifi.sta.config({ssid=SSID, pwd=PASSWORD})
-- wifi.sta.connect() not necessary because config() uses auto-connect=true by default
-- application.lua
periodic_task = function()
-- custom application ...
-- YOUR CODE HERE
print("connected to AP "..tostring(connected_to_AP))
tmr.create():alarm(10000, tmr.ALARM_SINGLE, periodic_task)
print("now running the application")
