- Thu Apr 30, 2015 9:35 am
#16095
So, I now installed ESPlorer v0.2.0. The [Save&Compile All] button doesn't work at all.
I did the following step by step:
- [Format] button
- open every .lua file, which creates a separate tab for each file
- edit ntp.lua and set your SSID, password and timezone
- select every file (tab) and press button [Save to ESP] (ignore error messages like 'not enough memory')
- select every file except ntp.lua and press button [Save&Compile]
- check your saved files, in the Command tab press [List files], you should have a .lc file for each .lua file except for ntp.lua
- select the ntp.lua tab and press [Run], the pong clock should start after 2-3 seconds
- if everything works properly, rename ntp.lua to init.lua by entering file.rename("ntp.lua","init.lua") in the command field, press [Send]
I hope I didn't miss anything. Please let me know if it works for you.
