GPIO 2 state can be changed from any browser on your local network. Also works with Andriod and iOS devices.
Change "your-ssid" & "your-password". Load up and follow instructions on serial terminal.
* EasyloT sketch tweeked by Barnabybear - original @
* http://iot-playground.com/2-uncategorised/40-esp8266-wifi-relay-switch-arduino-ide
* This sketch demonstrates how to set up a simple HTTP-like server.
* The server will set a GPIO pin depending on the request
* http://server_ip/gpio/0 will set the GPIO2 low,
* http://server_ip/gpio/1 will set the GPIO2 high
* server_ip is the IP address of the ESP8266 module, will be
* printed to Serial when the module is connected.
const char* ssid = "your-ssid";
const char* password = "your-password";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
delay(10);
// prepare GPIO2
pinMode(2, OUTPUT);
digitalWrite(2, 0);
// Connect to WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Start the server
server.begin();
Serial.println("Server started @ ");
// Print the IP address & instructions
Serial.println("To control GPIO, open your web browser.");
Serial.println("To set GPIO 2 high, type:");
Serial.print(WiFi.localIP());
Serial.println("/gpio/1");
Serial.println("To set GPIO 2 low, type:");
Serial.println("/gpio/0");
Serial.println("To toggle GPIO 2, type:");
Serial.println("/gpio/2");
if (!client) {
delay(100);
return;
// Commented out by BB as gets stuck in while loop.
//Serial.println("new client");
//while(!client.available()){
// delay(1);
Serial.println(req);
client.flush();
// Match the request
int val;
if (req.indexOf("/gpio/0") != -1)
val = 0;
else if (req.indexOf("/gpio/1") != -1)
val = 1;
else if (req.indexOf("/gpio/2") != -1)
val = (!digitalRead(2)); // <<<<< Edit: insert /gpio/3 lines after this line.
else {
Serial.println("invalid request");
client.print("HTTP/1.1 404\r\n");
client.stop();
return;
// Set GPIO2 according to the request
digitalWrite(2, val);
client.flush();
// Prepare the response
String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now ";
s += (val)?"high":"low";
s += "</html>\n";
// Send the response to the client
client.print(s);
delay(1);
Serial.println("Client disonnected");
// The client will actually be disconnected
// when the function returns and 'client' object is detroyed
A good starting place for many projects.
Have fun.
Edit: If you insert the following code,the suffix /gpio/3 will return the current state of the output without changing it.
else if (req.indexOf("/gpio/3") != -1)
val = (digitalRead(2));
