The boxes seems plenty big to house all the electronics, but they are actually only just big enough.
Just a quick test to check if the measurements I did for the devices in Eagle was correct.
Testing it in the box too, which was lucky, because I had some things a few millimeters off, and if I had not found that problem and corrected it, the pcb would not fit in the box.
A few rendered pictures of the pcb from top and bottom
- More info about the project on my blog http://captain-slow.dk/2015/11/14/wifi-switchbox/ where I also will release the source files once I have tested if the pcb works as expected, and fits inside the box.
