Simply place pullups on RES/SDA/SCL, and attach SDA/SCL on GPIO0/GPIO2, and that is it.
Using Arduino IDE ESP framework Wire library along with Adafruit_MCP23017 library, you will be able to drive 16 GPIO outputs.
Explore... Chat... Share...
