- Fri Apr 17, 2015 8:54 am
#14818
Hi , This is not exactly what you need but may be good starting point .
Modbus TCP bridge . TCP in MODBUS RTU on RXD and TXD out .
-- Modbus TCP bridge
-- listen on port XX
packet={}
packet_ptr=1
T_ID=0x0000
P_ID=0x0000
U_ID=0x0000
P_LEN=0x00
crc=0xFFFF
for i=1,20 do packet[i]=0x00 end
uart.setup(0,9600,8,0,1,0)
uart.write(0,"Start")
-- Initialize TCP server
sv=net.createServer(net.TCP, 60)
global_c = nil
sv:listen(502, function(c)
if global_c~=nil then
global_c:close()
global_c=c
c:on("receive",function(sck,pl) SendToSlave(pl) end)
end)
-- Receive data back from Slave
uart.on("data",1, function(data)
if ( packet_ptr==3)
then
if ( packet[2]<5)
then
MB_len=string.byte(data,1)+3
MB_len=4+2
packet[packet_ptr]=string.byte(data,1)
if ((MB_len>0) and (packet_ptr>=(MB_len+2)))
then
SendTCPBack()
packet_ptr=packet_ptr+1
end, 0)
function SendTCPBack()
global_c:send(word2str(T_ID))
global_c:send(word2str(P_ID))
global_c:send(word2str(MB_len))
for i=1,MB_len
do
global_c:send(string.char(packet[i]))
function SendToSlave(pld)
local i
local nb=0
local str
--uart.write(0,pld)
--uart.write(0,' ')
T_ID=string.byte(pld,1)*256+string.byte(pld,2)
P_ID=string.byte(pld,3)*256+string.byte(pld,4)
P_LEN=string.byte(pld,5)*256+string.byte(pld,6)
U_ID=string.byte(pld,7)
crc=0xFFFF
nb=P_LEN
for i=1,nb,1
do
b=string.byte(pld,i+6)
uart.write(0,string.char(b))
MBusCRC(b)
str=string.char(bit.band(crc,0xFF))
uart.write(0,str)
str=string.char(bit.rshift(crc,8))
uart.write(0,str)
packet_ptr=1
MB_len=0
-- MbusCRC
function MBusCRC(b)
crc = bit.bxor(crc, b)
for i=1,8 do
local j = bit.band(crc, 1)
crc = bit.rshift(crc, 1)
if j ~= 0 then
crc = bit.bxor(crc, 0xA001)
-- 2 bytes to string
function word2str(w)
local s
s=string.char(bit.rshift(w,8))
s=s..string.char(bit.band(w,0xFF))
return (s)
