What I cannot figure out is how to autofill the input text, using the value parameter, with a variable from the sketch.
In the listed code, I use the webserver input to populate the variable ap_SSID, ap_Password, and Local_Device_One. What I would like to have happen is when the webpage is invoked at a later date is for the text input to be autofilled with the values held by these three variables.
I've seen conversations about using a javascript, I just don't have enough knowledge to decipher and apply them to my setting. Any help is appreciated. Thank you.
Here is my code (trimmed to the conversation).
#include <FS.h>
#include <arduino.h>
#include <ArduinoJson.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266WebServer.h>
ESP8266WiFiMulti wifiMulti;
ESP8266WebServer server(80);
String webPage; //to store html code from htmlpage
//Variable for sample action
char Local_Device_One[25];
//Define the local IP variables
char ap_SSID[15] = "New Box"; //SSID for ESP when in AP mode
char ap_Password[9] = "password"; //Password for ESP when in AP mode
const char htmlPage[]PROGMEM=R"=====(
<!DOCTYPE html>
<html>
<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">
<link rel=\"icon\" href=\"data:,\">
<style>body { text-align: center; font-family: \"Trebuchet MS\", Arial;}
table { border-collapse:collapse; width:35%; margin-left:auto; margin-right:auto; }
th { padding:12px; background-color: #0043af; color: white; }
tr { border:1px solid #ddd; padding:12px; }
tr:hover { background-color: #bcbcbc; }
td { border: none; padding:12px; }
.button {background-color: #195B6A; border: none; color: white; padding: 12px 40px;
text-direction: none; font-size: 30px; margin: 2px; cursor: pointer;}
server.send(200,"</style></head><body><h1>Device Configuration Portal</h1>
<FORM METHOD="POST"action="/">
<h3>Access Point Credentials</h3>
<table>
<tr><th>Name</th><td><input type="text" name="custom_ap_SSID" value=ap_SSID></td></tr>
<tr><th>Password</th><td><input type="text" name="custom_ap_Password" value=ap_Password></td></tr>
<tr><th>Device One</th><td><input type="text" name="custom_Local_Device_One" value="Local_Device_One"></td></tr>
</table>
<input type="submit" value="Submit Changes">
</form>
</body>
</html>
void handleConfigurationPage() {
webPage=htmlPage;
server.arg("custom_ap_SSID").toCharArray(ap_SSID,15);
server.arg("custom_ap_Password").toCharArray(ap_Password,9);
server.arg("custom_Local_Device_One").toCharArray(Local_Device_One,25);
Serial.println("Text Received, contents:");
Serial.println("AP SSID");
Serial.println(ap_SSID);
Serial.println("AP Password:");
Serial.println(ap_Password);
Serial.println("Local Device one is:");
Serial.println(Local_Device_One);
server.send(200,"text/html",webPage);
//save the custom parameters to FS
Serial.println("saving config");
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.createObject();
json["ap_SSID"] = ap_SSID;
json["ap_Password"] = ap_Password;
json["Local_Device_One"] = Local_Device_One;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
json.prettyPrintTo(Serial);
json.printTo(configFile);
configFile.close();
//end save
void setupWifi() {
// WiFi.mode(WIFI_STA);
wifiMulti.addAP("SSID1", "PW1");
wifiMulti.addAP("SSID2", "PW2");
wifiMulti.addAP("SSID3", "PW3");
wifiMulti.addAP("SSID4", "PW4");
Serial.println("Connecting Wifi...");
while (wifiMulti.run() != WL_CONNECTED) {
Serial.print(".");
Serial.println("");
Serial.println("Connected to SSID: ");
Serial.println(WiFi.SSID());
// Serial.println();
// SPIFFS.format(); //clean FS, for testing
//read configuration from FS json
Serial.println("mounting FS...");
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
//file exists, reading and loading
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
size_t size = configFile.size();
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial);
if (json.success()) {
Serial.println("\nparsed json");
strcpy(ap_SSID, json["ap_SSID"]);
strcpy(ap_Password, json["ap_Password"]);
strcpy(Local_Device_One, json["Local_Device_One"]);
//add other variables here
} else {
Serial.println("failed to load json config");
} else {
Serial.println("failed to mount FS");
//end read
setupWifi();
server.on("/", handleConfigurationPage);
server.begin();
Serial.println("HTTP Server Started");
server.handleClient();
