Your ESP8266 is
https://pubsubclient.knolleary.net/api
Seeing and creating
Does it work?
I like below
There is a header file for each IC,
I have to apply each function
I thought it wouldn't move.
Is it a mistake?
To replace ESP32 with ESP8266
Things to think about
=Method=
Configurable with ESP8266
It is in "Esp32 MQTT Client.h"
Please tell me the next function.
bool Esp32MQTTClient_Init (const uint8_t * deviceConnString, bool hasDeviceTwin = false, bool traceOn = false);
And
"Bool Esp32MQTTClient_SendEvent (const char * text);"
For the following reasons
Because it is necessary.
The sketch example of ESP8266 is still in memory after compilation,
I can't compile.
And
"Azure-sdk-for-c.zip" library "
When I try to import it into the Ardino library,
Error occurs.
There are multiple Arduino library packages, so you just need to install them using the package manager. The library comes with multiple samples so you can easily see what to replace.
