I'll try to implement ur solution.
Thanks! ☺
Explore... Chat... Share...
scargill wrote:It would be great if someone would put a guide to all of this in one place for non-Linux people... every guide I've seen up to now makes massive assumptions. I would love to compile that http server in Windows- there's a problem with searching for access points that the original writer has yet to resolve and I'd love to know if others have solved it - also given that this will all be using the SDK 9.2 version, I can't imagine it lasting long before the memory eats away - hopefully resolved in 9.3
BUILD_BASE = build
FW_BASE = firmware
# Base directory for the compiler
XTENSA_TOOLS_ROOT ?= D:/ESP8266/Projects/esp8266/xtensa-lx106-elf-161014/xtensa-lx106-elf/bin
#Extra Tensilica includes from the
SDK_EXTRA_INCLUDES ?= D:/ESP8266/Projects/esp8266/esp_iot_sdk_v0.9.3/include
# base directory of the ESP8266 SDK package, absolute
SDK_BASE ?= D:/ESP8266/Projects/esp8266/esp_iot_sdk_v0.9.3
#Esptool.py path and port
ESPTOOL ?= esptool
ESPPORT ?= com1
# name for the target project
TARGET = httpd
# which modules (subdirectories) of the project to include in compiling
MODULES = driver user
EXTRA_INCDIR = include \
lib/heatshrink/ \
$(SDK_EXTRA_INCLUDES)
# libraries used in this project, mainly provided by the SDK
LIBS = c gcc pp hal phy net80211 lwip wpa main
# Added pp for SDK 9.3
# compiler flags using during compilation of source files
CFLAGS = -Os -ggdb -std=c99 -Werror -Wpointer-arith -Wundef -Wall -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -D__ets__ -DICACHE_FLASH
# linker flags used to generate the main object file
LDFLAGS = -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static
# linker script used for the above linkier step
LD_SCRIPT = eagle.app.v6.ld
# various paths from the SDK used in this project
SDK_LIBDIR = lib
SDK_LDDIR = ld
SDK_INCDIR = include include/json
# we create two different files for uploading into the flash
# these are the names and options to generate them
FW_FILE_1 = 0x00000
FW_FILE_1_ARGS = -bo $@ -bs .text -bs .data -bs .rodata -bc -ec
FW_FILE_2 = 0x40000
FW_FILE_2_ARGS = -es .irom0.text $@ -ec
# select which tools to use as compiler, librarian and linker
CC := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-gcc
AR := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-ar
LD := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-gcc
#### no user configurable options below here
FW_TOOL ?= /usr/bin/esptool
SRC_DIR := $(MODULES)
BUILD_DIR := $(addprefix $(BUILD_BASE)/,$(MODULES))
SDK_LIBDIR := $(addprefix $(SDK_BASE)/,$(SDK_LIBDIR))
SDK_INCDIR := $(addprefix -I$(SDK_BASE)/,$(SDK_INCDIR))
SRC := $(foreach sdir,$(SRC_DIR),$(wildcard $(sdir)/*.c))
OBJ := $(patsubst %.c,$(BUILD_BASE)/%.o,$(SRC))
LIBS := $(addprefix -l,$(LIBS))
APP_AR := $(addprefix $(BUILD_BASE)/,$(TARGET)_app.a)
TARGET_OUT := $(addprefix $(BUILD_BASE)/,$(TARGET).out)
LD_SCRIPT := $(addprefix -T$(SDK_BASE)/$(SDK_LDDIR)/,$(LD_SCRIPT))
INCDIR := $(addprefix -I,$(SRC_DIR))
EXTRA_INCDIR := $(addprefix -I,$(EXTRA_INCDIR))
MODULE_INCDIR := $(addsuffix /include,$(INCDIR))
FW_FILE_1 := $(addprefix $(FW_BASE)/,$(FW_FILE_1).bin)
FW_FILE_2 := $(addprefix $(FW_BASE)/,$(FW_FILE_2).bin)
V ?= $(VERBOSE)
ifeq ("$(V)","1")
Q :=
vecho := @true
Q := @
vecho := @echo
endif
vpath %.c $(SRC_DIR)
define compile-objects
$1/%.o: %.c
$(vecho) "CC $$<"
$(Q) $(CC) $(INCDIR) $(MODULE_INCDIR) $(EXTRA_INCDIR) $(SDK_INCDIR) $(CFLAGS) -c $$< -o $$@
endef
.PHONY: all checkdirs clean
all: checkdirs $(TARGET_OUT) $(FW_FILE_1) $(FW_FILE_2)
$(FW_FILE_1): $(TARGET_OUT) firmware
$(vecho) "FW $@"
$(Q) $(FW_TOOL) -eo $(TARGET_OUT) $(FW_FILE_1_ARGS)
$(FW_FILE_2): $(TARGET_OUT) firmware
$(vecho) "FW $@"
$(Q) $(FW_TOOL) -eo $(TARGET_OUT) $(FW_FILE_2_ARGS)
$(TARGET_OUT): $(APP_AR)
$(vecho) "LD $@"
$(Q) $(LD) -L$(SDK_LIBDIR) $(LD_SCRIPT) $(LDFLAGS) -Wl,--start-group $(LIBS) $(APP_AR) -Wl,--end-group -o $@
$(APP_AR): $(OBJ)
$(vecho) "AR $@"
$(Q) $(AR) cru $@ $^
checkdirs: $(BUILD_DIR) $(FW_BASE)
$(BUILD_DIR):
$(Q) mkdir -p $@
firmware:
$(Q) mkdir -p $@
flash: $(FW_FILE_1) $(FW_FILE_2)
-$(ESPTOOL) --port $(ESPPORT) write_flash 0x00000 firmware/0x00000.bin
sleep 3
-$(ESPTOOL) --port $(ESPPORT) write_flash 0x40000 firmware/0x40000.bin
# These automations are only required and should be design as per need and application.
webpages.espfs: html/ mkespfsimage/mkespfsimage
cd html; find | ../mkespfsimage/mkespfsimage > ../webpages.espfs; cd ..
mkespfsimage/mkespfsimage: mkespfsimage/
make -C mkespfsimage
htmlflash: webpages.espfs
if [ $$(stat -c '%s' webpages.espfs) -gt $$(( 0x2E000 )) ]; then echo "webpages.espfs too big!"; false; fi
-$(ESPTOOL) --port $(ESPPORT) write_flash 0x12000 webpages.espfs
# Don't change anything below!
clean:
$(Q) rm -f $(APP_AR)
$(Q) rm -f $(TARGET_OUT)
$(Q) find $(BUILD_BASE) -type f | xargs rm -f
$(Q) rm -f $(FW_FILE_1)
$(Q) rm -f $(FW_FILE_2)
$(Q) rm -rf $(FW_BASE)
$(foreach bdir,$(BUILD_DIR),$(eval $(call compile-objects,$(bdir))))
