By Marek Coufal
#58563 Hello, I am trying adafruit io server and adafruit mqtt library. Two dayes ago, my first ESP8266 - ESP01. I tried programming esp8266 via Arduino IDE and it worked. I blinked LED and created small webserver with it. So i tried upload code for controlling lamp from web of adafruit, changed only ssid, vpassword, AIo key and AI username
Code: Select all  Adafruit MQTT Library ESP8266 Example
  Must use ESP8266 Arduino from:
    https://github.com/esp8266/Arduino
  Works great with Adafruit's Huzzah ESP board:
  ----> https://www.adafruit.com/product/2471
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Tony DiCola for Adafruit Industries.
  Adafruit IO example additions by Todd Treece.
  MIT license, all text above must be included in any redistribution
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
// function prototypes
void connect(void);
/****************************** Pins ******************************************/
#define LAMP            2  // power switch tail
/************************* WiFi Access Point *********************************/
#define WLAN_SSID       "shaun_net"
#define WLAN_PASS       "heslojeproblbce"
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883
#define AIO_USERNAME    "marouncz"
#define AIO_KEY         "2851df6c2c264e829018f3f17cde4fd2"
/************ Global State (you don't need to change this!) ******************/
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClient client;
// Store the MQTT server, client ID, username, and password in flash memory.
// This is required for using the Adafruit MQTT library.
const char MQTT_SERVER[] PROGMEM    = AIO_SERVER;
// Set a unique MQTT client ID using the AIO key + the date and time the sketch
// was compiled (so this should be unique across multiple devices for a user,
// alternatively you can manually set this to a GUID or other random value).
const char MQTT_CLIENTID[] PROGMEM  = __TIME__ AIO_USERNAME;
const char MQTT_USERNAME[] PROGMEM  = AIO_USERNAME;
const char MQTT_PASSWORD[] PROGMEM  = AIO_KEY;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, MQTT_SERVER, AIO_SERVERPORT, MQTT_CLIENTID, MQTT_USERNAME, MQTT_PASSWORD);
/****************************** Feeds ***************************************/
// Setup a feed called 'lamp' for subscribing to changes.
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>
const char LAMP_FEED[] PROGMEM = AIO_USERNAME "/feeds/lamp";
Adafruit_MQTT_Subscribe lamp = Adafruit_MQTT_Subscribe(&mqtt, LAMP_FEED);
/*************************** Sketch Code ************************************/
  // set power switch tail pin as an output
  pinMode(LAMP, OUTPUT);
  Serial.println(F("Adafruit IO Example"));
  // Connect to WiFi access point.
  Serial.println(); Serial.println();
  delay(10);
  Serial.print(F("Connecting to "));
  Serial.println(WLAN_SSID);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
    Serial.print(F("."));
  Serial.println(F("WiFi connected"));
  Serial.println(F("IP address: "));
  // listen for events on the lamp feed
  mqtt.subscribe(&lamp);
  // connect to adafruit io
  connect();
  Adafruit_MQTT_Subscribe *subscription;
  // ping adafruit io a few times to make sure we remain connected
  if(! mqtt.ping(3)) {
    // reconnect to adafruit io
    if(! mqtt.connected())
      connect();
  // this is our 'wait for incoming subscription packets' busy subloop
  while (subscription = mqtt.readSubscription(1000)) {
    // we only care about the lamp events
    if (subscription == &lamp) {
      // convert mqtt ascii payload to int
      char *value = (char *)lamp.lastread;
      Serial.print(F("Received: "));
      Serial.println(value);
      int current = atoi(value);
      // write the current state to the power switch tail
      digitalWrite(LAMP, current == 1 ? HIGH : LOW);
// connect to adafruit io via MQTT
void connect() {
  Serial.print(F("Connecting to Adafruit IO... "));
  int8_t ret;
  while ((ret = mqtt.connect()) != 0) {
    switch (ret) {
      case 1: Serial.println(F("Wrong protocol")); break;
      case 2: Serial.println(F("ID rejected")); break;
      case 3: Serial.println(F("Server unavail")); break;
      case 4: Serial.println(F("Bad user/pass")); break;
      case 5: Serial.println(F("Not authed")); break;
      case 6: Serial.println(F("Failed to subscribe")); break;
      default: Serial.println(F("Connection failed")); break;
    if(ret >= 0)
      mqtt.disconnect();
    Serial.println(F("Retrying connection..."));
    delay(5000);
  Serial.println(F("Adafruit IO Connected!"));
I uploaded this code to ESP and open Serial monitor it doesn´t work and it shows this error message?
ets Jan 8 2013,rst cause:4, boot mode:(3,7)
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v3de0c112
~ld
So i thought, It is bad memory chip. So I bought another esp8266 this time nodemcu board and still nothing.
Please can someone help me to selve this problem?
Thanks
