By Ivica Matić
#67833 Hello guys and girls!
First time,first post :)
I am wondering is my code going to work.
I need to create small numbers of weather stations for school project and i need confirmation of my code so they can order all needed parts.The data should be uploaded to ThingSpeak every 60 minutes.
Code: Select all#include "ThingSpeak.h"
#include "ESP8266WiFi.h"
/*------wifi data ------*/
char ssid[] = "Ivica_wifI";
char wifipass[] = "Ivicawifi0968";
/*-------ThingSpeak data-------------*/
char api_write_key[] = "umetni kljuc ovdje";
long api_write_channel = 123456;
  WiFiClient ts_client;
   WiFi.mode(WIFI_STA);
   WiFi.begin(ssid, wifipass);
     ThingSpeak.begin(ts_client);
     int val1 = random(0,999);
     ThingSpeak.setField(0, val1);
     ThingSpeak.writeFields(api_write_channel, api_write_key);
     ESP.deepSleep(60 * 1000 * 60);
By torntrousers
#67843 DeepSleep is in microseconds so
Code: Select allESP.deepSleep(60 * 1000 * 60);
should probably be
Code: Select allESP.deepSleep(60 * 60 * 1000000);
Also, this wait:
Code: Select allwhile (WiFi.status() != WL_CONNECTED) {
should have a delay or yield inside it to give background tasks a chance to run. Its also a good idea to have a timeout on the wait in case there is some problem with the Wifi connection and go back to sleep if it times out and try again later.
By Ivica Matić
#67846
torntrousers wrote:DeepSleep is in microseconds so
should probably be
Also, this wait:
Thank you for your response :)
Wow.So many errors in such simple code :lol: .Can you please explain to me what is yield() function all about.Does it provide priority to ESPs other functions before my code.Does it work like that?
