I am new to this esp8266 and need some help to run a quick test if this module is of use to me.
The esp8266 I am using is from digikey partnumber 1568-1235-ND (most common module)
What I like to test is:
- One esp6288 with push button on the gpio2
- Second esp8266 with external led on gpio2
- both powered by ftdi-board and usb cable to the pc
- Direct communication between these two esp8266 by wifi (without using Arduino, raspberry or so)
- when the pushbutton is pushed, the led on the other esp8266 should light up
(if possible also output (print) to PC-screen by the ftdi connection)
Can any one supply me the code for both units? I like to program the modules using the Arduino IDE
It would be a great help. Many thanks in advance
Regards'
Frans
