WiFi connected
IP address:
10.0.1.24
connecting to api.thingspeak.com
distance (cm) =135.06500
Posting to Thingspeak
Done Posting to Thingspeak
distance (cm) =64.54900
distance (cm) =64.12400
Posting to Thingspeak.
...etc.
This looks good and well but when I go to my ThingSpeak channel, there is no data uploaded and the graph is blank.
My hardware setup is attached, and my Arduino IDE code is as follows:
#include <stdlib.h>
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h> #include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include <ThingSpeak.h> //<<<<<I HAD FORGOTTON THIS>>>>>>
int Trig = 14;
int Echo = 12;
//Wifi Host
const char* ssid = "spoomouse_3T";
const char* password = "merci8cake";
WiFiClient client;
//Server Information
const char* host = "api.thingspeak.com";
const int postingInterval = 30 * 1000; // post data every 30 seconds to prevent missing points
// ThingSpeak Ultrasonic Channel
const int TempchannelID = 337019;
String apiIP = "184.106.153.149";
String apiKey = "VZ4EW5LYJNHJ011C";
// write API key for your ThingSpeak Channel
//SoftwareSerial softwareSerial(rxPin, txPin);
float soundVelocity = 0.034;
void setup()
//HC-SR04 setup pins
pinMode(Trig, OUTPUT);
pinMode(Echo, INPUT);
delay(2000);
bool status;
// default settings
Serial.println("-- Default Test --");
delay(5000);
// Now we connect to a WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.print("");
Serial.print("WiFi connected");
Serial.print("IP address: ");
Serial.print(WiFi.localIP());
int value = 0;
delay(5000);
++value;
Serial.println(host);
///////////MAIN LOOP//////////////
float distance = getDistance();
Serial.print("distance (cm) =");
Serial.print(distance, 5);
Serial.print("\n");
//Create String using value
String body = "field1=";
body += String(distance, 2);
Serial.print("Posting to Thingspeak");
//Post on the channel
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: " + apiKey + "\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(body.length());
client.print("\n\n");
client.print(body);
delay(postingInterval);
Serial.println("Done Posting to Thingspeak");
// wait and then post again
client.stop();
/////////FUNCTION GETDISTANCE///////////
float getDistance ()
{ //collect values
digitalWrite(Trig, HIGH);
delayMicroseconds(10);
digitalWrite(Trig, LOW);
long highleveltime = pulseIn(Echo, HIGH);
// Serial.print(highleveltime);
//Serial.print("\n");
float distance = (float (highleveltime) * soundVelocity) / 2.0;
return distance;
If there's anything you guys can see that could cause this, or even any debugging tips, I'd be grateful for your advice. Trying to get this working by tomorrow
