- Thu Apr 22, 2021 9:28 am
#91169
It shouldn't be a real problem; it actually depends on what you want and need.
Please note that:
- By default the ESP8266 can only handle 4 concurrent connections at a time
- The internal memory (using SPIFFS or LittleFS) is limited, so you might want to resort to an external SD-interface/card for the actual data (not sure what the actual max addressable SD size and file size is with current libraries) if the files are going to be large
- The transfer speed of the ESP8266 is limited; not a problem with small files, but if you want to share video clips or music files it will be an unsatisfying experience
It might be a nice idea to try out some example sketches yourself, to get a gasp of what might be needed.
If you will be using the Arduino IDE, I believe the "FSBrowser" example ("File" -> "Examples" -> "ESP8266WebServer" -> "FSBrowser") might be nice code to start off with (please note: i have only looked a bit at the code to see if it somewhat matches what you're searching for; I haven't used it myself, so I might be wrong).
I have no experience with other environments, so can't comment on those, but I'm sure it can be done with those as well.
Assumption is the mother of all f*ckups. At least: that's what I'm assuming.
