By happygneddu
#3916 Yes, if use this url : http://api.pushingbox.com/pushingbox?devid=mydevid with browser, the notification arrive.
I have tried to send : POST http://api.pushingbox.com/pushingbox?devid=mydevid HTTP/1.0\r\nUser-Agent: ESP8266
but the answer is only :
SEND OK
OK
Unlink
and the notification does not arrive...
By happygneddu
#3928 marciel310 you are right. https and http is not the same but the response is equal.
I tried to send GET /pushingbox?devid=mydevid HTTP/1.1\r\nHost: api.pushingbox.com or GET /pushingbox?devid=mydevid HTTP/1.0\r\nHost: api.pushingbox.com and the response is :
SEND OK
OK
Unlink
nothing else and the notification does not arrive :x :x
The only times I get response are when send GET http://api.pushingbox.com/pushingbox?devid=mydevid HTTP/1.0
and the response is like the second post...
The problem may be in the number of characters that send ?
By Tomer
#3930
happygneddu wrote:marciel310 you are right. https and http is not the same but the response is equal.
SEND OK
OK
Unlink
Like maciel said, looks like its shared hosting, so your request should must include a host header, it should look something like this:
GET /pushingbox?devid=<YOURDEVID> HTTP/1.1\r\nHost: api.pushingbox.com\r\nUser-Agent: ESP8266\r\n\r\n
** Just make sure that you are replacing <YOURDEVID> with your correct dev id, and that you are calculating the correct length
